Time Before: 0.00265 seconds
Time After: 0.00326 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00337 seconds
Time After: 0.00385 seconds
Time Before: 0.00407 seconds
Time After: 0.00419 seconds
Time Before: 0.00490 seconds
Time After: 0.00785 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00424 seconds
Time After: 0.01125 seconds
Time Taken: 0.00701 seconds
Time Before: 0.01326 seconds
Time After: 0.01373 seconds
Time Before: 0.01683 seconds
Time After: 0.01812 seconds
Time Before: 0.01267 seconds
Time After: 0.01830 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02391 seconds
Time After: 0.02403 seconds
Time Before: 0.02609 seconds
Time After: 0.02733 seconds
End call of global.php: 0.028995990753174
Time Before: 0.03079 seconds
Time After: 0.03136 seconds
Time Taken: 0.00057 seconds
Time Before: 0.03343 seconds
Time After: 0.03485 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102324', badlocation = 1
Time Before: 0.04742 seconds
Time After: 0.04791 seconds
Page generated in 0.046518087387085 seconds with 9 queries, spending 0.0091550350189209 doing MySQL queries and 0.037363052368164 doing PHP things.
