Time Before: 0.00201 seconds
Time After: 0.00263 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00273 seconds
Time After: 0.00321 seconds
Time Before: 0.00345 seconds
Time After: 0.00359 seconds
Time Before: 0.00456 seconds
Time After: 0.00733 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00367 seconds
Time After: 0.01277 seconds
Time Taken: 0.00909 seconds
Time Before: 0.01512 seconds
Time After: 0.01558 seconds
Time Before: 0.01892 seconds
Time After: 0.02022 seconds
Time Before: 0.01440 seconds
Time After: 0.02047 seconds
Time Taken: 0.00608 seconds
Time Before: 0.02686 seconds
Time After: 0.02699 seconds
Time Before: 0.02879 seconds
Time After: 0.03007 seconds
Time Before: 0.03304 seconds
Time After: 0.03323 seconds
Time Before: 0.03626 seconds
Time After: 0.03776 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102337' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05428 seconds
Time After: 0.05460 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
