Time Before: 0.00155 seconds
Time After: 0.00206 seconds
Time Before: 0.00213 seconds
Time After: 0.00251 seconds
Time Before: 0.00274 seconds
Time After: 0.00288 seconds
Time Before: 0.00369 seconds
Time After: 0.00609 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00295 seconds
Time After: 0.00949 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01158 seconds
Time After: 0.01201 seconds
Time Before: 0.01468 seconds
Time After: 0.01590 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01072 seconds
Time After: 0.01615 seconds
Time Taken: 0.00542 seconds
Memory After: 2,261.703 KB
Time Before: 0.02278 seconds
Time After: 0.02292 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02539 seconds
Time After: 0.02663 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029032945632935
Time Before: 0.03073 seconds
Time After: 0.03096 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03419 seconds
Time After: 0.03565 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=102338', badlocation = 1
Time Before: 0.04864 seconds
Time After: 0.04898 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.047704935073853 seconds with 9 queries, spending 0.0079841613769531 doing MySQL queries and 0.039720773696899 doing PHP things.
