Time Before: 0.00367 seconds
Time After: 0.00480 seconds
Time Taken: 0.00113 seconds
Time Before: 0.00490 seconds
Time After: 0.00533 seconds
Time Before: 0.00556 seconds
Time After: 0.00568 seconds
Time Before: 0.00664 seconds
Time After: 0.00894 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00577 seconds
Time After: 0.01485 seconds
Time Taken: 0.00908 seconds
Time Before: 0.01739 seconds
Time After: 0.01774 seconds
Time Before: 0.02026 seconds
Time After: 0.02145 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01681 seconds
Time After: 0.02166 seconds
Time Taken: 0.00485 seconds
Memory After: 2,261.703 KB
Time Before: 0.02691 seconds
Time After: 0.02705 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02908 seconds
Time After: 0.03030 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.032908201217651
Time Before: 0.03439 seconds
Time After: 0.03457 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03747 seconds
Time After: 0.03890 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=102351', badlocation = 1
Time Before: 0.05245 seconds
Time After: 0.05268 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.051545143127441 seconds with 9 queries, spending 0.0075798034667969 doing MySQL queries and 0.043965339660645 doing PHP things.
