Time Before: 0.00150 seconds
Time After: 0.00201 seconds
Time Before: 0.00209 seconds
Time After: 0.00261 seconds
Time Before: 0.00284 seconds
Time After: 0.00297 seconds
Time Before: 0.00377 seconds
Time After: 0.00652 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00301 seconds
Time After: 0.00990 seconds
Time Taken: 0.00689 seconds
Time Before: 0.01196 seconds
Time After: 0.01245 seconds
Time Before: 0.01546 seconds
Time After: 0.01663 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01121 seconds
Time After: 0.01679 seconds
Time Taken: 0.00558 seconds
Memory After: 2,261.703 KB
Time Before: 0.02166 seconds
Time After: 0.02179 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02381 seconds
Time After: 0.02502 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.026652812957764
Time Before: 0.02841 seconds
Time After: 0.02875 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03099 seconds
Time After: 0.03249 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=102355', badlocation = 1
Time Before: 0.04482 seconds
Time After: 0.04522 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.043905973434448 seconds with 9 queries, spending 0.0086472034454346 doing MySQL queries and 0.035258769989014 doing PHP things.
