Time Before: 0.00819 seconds
Time After: 0.01064 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01071 seconds
Time After: 0.01108 seconds
Time Before: 0.01131 seconds
Time After: 0.01143 seconds
Time Before: 0.01234 seconds
Time After: 0.01457 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01148 seconds
Time After: 0.01870 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02279 seconds
Time After: 0.02322 seconds
Time Before: 0.02674 seconds
Time After: 0.02801 seconds
Time Before: 0.02207 seconds
Time After: 0.02824 seconds
Time Taken: 0.00617 seconds
Time Before: 0.04440 seconds
Time After: 0.04453 seconds
Time Before: 0.05237 seconds
Time After: 0.05377 seconds
Time Taken: 0.00139 seconds
Time Before: 0.05976 seconds
Time After: 0.05995 seconds
Time Before: 0.06252 seconds
Time After: 0.06398 seconds
UPDATE session SET lastactivity = 1783167376, location = '/forums/private.php?do=newpm&explain=1&u=102358' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.07885 seconds
Time After: 0.07914 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
