Time Before: 0.02176 seconds
Time After: 0.02862 seconds
Time Taken: 0.00686 seconds
Time Before: 0.02874 seconds
Time After: 0.02919 seconds
Time Before: 0.02940 seconds
Time After: 0.02952 seconds
Time Before: 0.03062 seconds
Time After: 0.03266 seconds
Time Taken: 0.00204 seconds
Time Before: 0.02958 seconds
Time After: 0.03706 seconds
Time Taken: 0.00747 seconds
Time Before: 0.04579 seconds
Time After: 0.04603 seconds
Time Before: 0.04848 seconds
Time After: 0.04971 seconds
Time Before: 0.04515 seconds
Time After: 0.04996 seconds
Time Taken: 0.00481 seconds
Time Before: 0.07998 seconds
Time After: 0.08015 seconds
Time Before: 0.38691 seconds
Time After: 0.38824 seconds
Time Taken: 0.00133 seconds
Time Before: 0.39780 seconds
Time After: 0.39796 seconds
Time Before: 0.40074 seconds
Time After: 0.40218 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102361', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.42367 seconds
Time After: 0.42397 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
