Time Before: 0.01033 seconds
Time After: 0.01455 seconds
Time Taken: 0.00422 seconds
Time Before: 0.01462 seconds
Time After: 0.01504 seconds
Time Before: 0.01528 seconds
Time After: 0.01540 seconds
Time Before: 0.01639 seconds
Time After: 0.02024 seconds
Time Taken: 0.00385 seconds
Time Before: 0.01547 seconds
Time After: 0.02450 seconds
Time Taken: 0.00903 seconds
Time Before: 0.03136 seconds
Time After: 0.03160 seconds
Time Before: 0.03415 seconds
Time After: 0.03540 seconds
Time Before: 0.03061 seconds
Time After: 0.03567 seconds
Time Taken: 0.00505 seconds
Time Before: 0.05561 seconds
Time After: 0.05578 seconds
Time Before: 0.07141 seconds
Time After: 0.07268 seconds
End call of global.php: 0.074581861495972
Time Before: 0.07965 seconds
Time After: 0.07982 seconds
Time Before: 0.08205 seconds
Time After: 0.08356 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1776668096, location = '/forums/private.php?do=newpm&explain=1&u=102367', badlocation = 1
Time Before: 0.09955 seconds
Time After: 0.09985 seconds
Page generated in 0.098532915115356 seconds with 9 queries, spending 0.0092930793762207 doing MySQL queries and 0.089239835739136 doing PHP things.
