Time Before: 0.00183 seconds
Time After: 0.00239 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00245 seconds
Time After: 0.00366 seconds
Time Before: 0.00391 seconds
Time After: 0.00405 seconds
Time Before: 0.00470 seconds
Time After: 0.00694 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00410 seconds
Time After: 0.01030 seconds
Time Taken: 0.00621 seconds
Time Before: 0.01225 seconds
Time After: 0.01268 seconds
Time Before: 0.01516 seconds
Time After: 0.01635 seconds
Time Before: 0.01154 seconds
Time After: 0.01653 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02169 seconds
Time After: 0.02197 seconds
Time Before: 0.02395 seconds
Time After: 0.02534 seconds
Time Taken: 0.00139 seconds
Time Before: 0.02806 seconds
Time After: 0.02821 seconds
Time Before: 0.03014 seconds
Time After: 0.03162 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102398' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04385 seconds
Time After: 0.04443 seconds
Time Taken: 0.00058 seconds
