Time Before: 0.00726 seconds
Time After: 0.01023 seconds
Time Taken: 0.00296 seconds
Time Before: 0.01032 seconds
Time After: 0.01070 seconds
Time Before: 0.01094 seconds
Time After: 0.01112 seconds
Time Before: 0.01213 seconds
Time After: 0.01441 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01119 seconds
Time After: 0.01842 seconds
Time Taken: 0.00723 seconds
Time Before: 0.02143 seconds
Time After: 0.02189 seconds
Time Before: 0.02451 seconds
Time After: 0.02572 seconds
Time Before: 0.02084 seconds
Time After: 0.02594 seconds
Time Taken: 0.00511 seconds
Time Before: 0.04003 seconds
Time After: 0.04021 seconds
Time Before: 0.04941 seconds
Time After: 0.05070 seconds
Time Before: 0.05785 seconds
Time After: 0.05813 seconds
Time Before: 0.06087 seconds
Time After: 0.06242 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102422', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08044 seconds
Time After: 0.08073 seconds
