Time Before: 0.00136 seconds
Time After: 0.00193 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00200 seconds
Time After: 0.00235 seconds
Time Before: 0.00254 seconds
Time After: 0.00270 seconds
Time Before: 0.00332 seconds
Time After: 0.00589 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00275 seconds
Time After: 0.00941 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01125 seconds
Time After: 0.01178 seconds
Time Before: 0.01438 seconds
Time After: 0.01599 seconds
Time Taken: 0.00161 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01067 seconds
Time After: 0.01616 seconds
Time Taken: 0.00549 seconds
Memory After: 2,261.703 KB
Time Before: 0.02172 seconds
Time After: 0.02189 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02372 seconds
Time After: 0.02502 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02789 seconds
Time After: 0.02803 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03009 seconds
Time After: 0.03154 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102427' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04442 seconds
Time After: 0.04780 seconds
Time Taken: 0.00338 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
