Time Before: 0.00213 seconds
Time After: 0.00357 seconds
Time Before: 0.00366 seconds
Time After: 0.00410 seconds
Time Before: 0.00437 seconds
Time After: 0.00450 seconds
Time Before: 0.00546 seconds
Time After: 0.00797 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00458 seconds
Time After: 0.01285 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01659 seconds
Time After: 0.01707 seconds
Time Before: 0.01963 seconds
Time After: 0.02083 seconds
Time Before: 0.01573 seconds
Time After: 0.02111 seconds
Time Taken: 0.00538 seconds
Time Before: 0.03084 seconds
Time After: 0.03100 seconds
Time Before: 0.03303 seconds
Time After: 0.03432 seconds
End call of global.php: 0.037177801132202
Time Before: 0.03969 seconds
Time After: 0.03990 seconds
Time Before: 0.04314 seconds
Time After: 0.04471 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102440', badlocation = 1
Time Before: 0.06354 seconds
Time After: 0.06432 seconds
Time Taken: 0.00078 seconds
Page generated in 0.062552928924561 seconds with 9 queries, spending 0.0087552070617676 doing MySQL queries and 0.053797721862793 doing PHP things.
