Time Before: 0.00502 seconds
Time After: 0.00670 seconds
Time Taken: 0.00168 seconds
Time Before: 0.00678 seconds
Time After: 0.00724 seconds
Time Before: 0.00751 seconds
Time After: 0.00765 seconds
Time Before: 0.00861 seconds
Time After: 0.01222 seconds
Time Taken: 0.00361 seconds
Time Before: 0.00773 seconds
Time After: 0.01645 seconds
Time Taken: 0.00872 seconds
Time Before: 0.01820 seconds
Time After: 0.01838 seconds
Time Before: 0.02171 seconds
Time After: 0.02331 seconds
Time Taken: 0.00161 seconds
Time Before: 0.01759 seconds
Time After: 0.02349 seconds
Time Taken: 0.00590 seconds
Time Before: 0.02915 seconds
Time After: 0.02930 seconds
Time Before: 0.03163 seconds
Time After: 0.03288 seconds
End call of global.php: 0.034499168395996
Time Before: 0.03581 seconds
Time After: 0.03595 seconds
Time Before: 0.03801 seconds
Time After: 0.03949 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102450', badlocation = 1
Time Before: 0.05803 seconds
Time After: 0.05837 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.056745052337646 seconds with 9 queries, spending 0.0093562602996826 doing MySQL queries and 0.047388792037964 doing PHP things.
