Time Before: 0.00196 seconds
Time After: 0.00258 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00268 seconds
Time After: 0.00322 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00356 seconds
Time After: 0.00375 seconds
Time Before: 0.00458 seconds
Time After: 0.00677 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00382 seconds
Time After: 0.01048 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01232 seconds
Time After: 0.01292 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01553 seconds
Time After: 0.01673 seconds
Time Before: 0.01175 seconds
Time After: 0.01691 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02199 seconds
Time After: 0.02219 seconds
Time Before: 0.02453 seconds
Time After: 0.02582 seconds
Time Before: 0.02863 seconds
Time After: 0.02879 seconds
Time Before: 0.03088 seconds
Time After: 0.03363 seconds
Time Taken: 0.00275 seconds
UPDATE session SET lastactivity = 1789143290, location = '/forums/private.php?do=newpm&explain=1&u=102458', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04926 seconds
Time After: 0.05266 seconds
Time Taken: 0.00340 seconds
