Time Before: 0.00627 seconds
Time After: 0.00920 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00930 seconds
Time After: 0.00977 seconds
Time Before: 0.01001 seconds
Time After: 0.01013 seconds
Time Before: 0.01089 seconds
Time After: 0.01325 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01020 seconds
Time After: 0.01747 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02294 seconds
Time After: 0.02334 seconds
Time Before: 0.02528 seconds
Time After: 0.02713 seconds
Time Taken: 0.00185 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02229 seconds
Time After: 0.02738 seconds
Time Taken: 0.00509 seconds
Memory After: 2,261.820 KB
Time Before: 0.03959 seconds
Time After: 0.04006 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.04833 seconds
Time After: 0.04960 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.051930904388428
Time Before: 0.05524 seconds
Time After: 0.05541 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.05857 seconds
Time After: 0.06002 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788965935, location = '/forums/private.php?do=newpm&explain=1&u=102459', badlocation = 1
Time Before: 0.07902 seconds
Time After: 0.07924 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.077913999557495 seconds with 9 queries, spending 0.0087909698486328 doing MySQL queries and 0.069123029708862 doing PHP things.
