Time Before: 0.00170 seconds
Time After: 0.00218 seconds
Time Before: 0.00224 seconds
Time After: 0.00284 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00310 seconds
Time After: 0.00340 seconds
Time Before: 0.00406 seconds
Time After: 0.00739 seconds
Time Taken: 0.00332 seconds
Time Before: 0.00345 seconds
Time After: 0.01247 seconds
Time Taken: 0.00901 seconds
Time Before: 0.01481 seconds
Time After: 0.01522 seconds
Time Before: 0.01766 seconds
Time After: 0.01886 seconds
Time Before: 0.01416 seconds
Time After: 0.01909 seconds
Time Taken: 0.00492 seconds
Time Before: 0.02603 seconds
Time After: 0.02624 seconds
Time Before: 0.02825 seconds
Time After: 0.02951 seconds
Time Before: 0.03335 seconds
Time After: 0.03356 seconds
Time Before: 0.03590 seconds
Time After: 0.03744 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=10249' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.05261 seconds
Time After: 0.05290 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
