Time Before: 0.00136 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00269 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00300 seconds
Time After: 0.00323 seconds
Time Before: 0.00396 seconds
Time After: 0.00669 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00330 seconds
Time After: 0.01009 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01205 seconds
Time After: 0.01250 seconds
Time Before: 0.01509 seconds
Time After: 0.01633 seconds
Time Before: 0.01149 seconds
Time After: 0.01651 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02171 seconds
Time After: 0.02191 seconds
Time Before: 0.02362 seconds
Time After: 0.02486 seconds
End call of global.php: 0.026451826095581
Time Before: 0.02755 seconds
Time After: 0.02775 seconds
Time Before: 0.02972 seconds
Time After: 0.03119 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102507', badlocation = 1
Time Before: 0.04374 seconds
Time After: 0.04400 seconds
Page generated in 0.042840957641602 seconds with 9 queries, spending 0.0087628364562988 doing MySQL queries and 0.034078121185303 doing PHP things.
