Time Before: 0.01416 seconds
Time After: 0.01812 seconds
Time Taken: 0.00397 seconds
Time Before: 0.01822 seconds
Time After: 0.01867 seconds
Time Before: 0.01895 seconds
Time After: 0.01909 seconds
Time Before: 0.01999 seconds
Time After: 0.02315 seconds
Time Taken: 0.00317 seconds
Time Before: 0.01920 seconds
Time After: 0.02796 seconds
Time Taken: 0.00876 seconds
Time Before: 0.03415 seconds
Time After: 0.03460 seconds
Time Before: 0.03747 seconds
Time After: 0.03872 seconds
Time Before: 0.03333 seconds
Time After: 0.03898 seconds
Time Taken: 0.00565 seconds
Time Before: 0.05819 seconds
Time After: 0.05844 seconds
Time Before: 0.07187 seconds
Time After: 0.07312 seconds
End call of global.php: 0.075753211975098
Time Before: 0.08041 seconds
Time After: 0.08062 seconds
Time Before: 0.08327 seconds
Time After: 0.08483 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102508', badlocation = 1
Time Before: 0.10462 seconds
Time After: 0.10488 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.10317015647888 seconds with 9 queries, spending 0.008969783782959 doing MySQL queries and 0.094200372695923 doing PHP things.
