Time Before: 0.00920 seconds
Time After: 0.01252 seconds
Time Taken: 0.00332 seconds
Time Before: 0.01262 seconds
Time After: 0.01325 seconds
Time Taken: 0.00063 seconds
Time Before: 0.01349 seconds
Time After: 0.01362 seconds
Time Before: 0.01447 seconds
Time After: 0.01682 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01367 seconds
Time After: 0.02131 seconds
Time Taken: 0.00763 seconds
Time Before: 0.02573 seconds
Time After: 0.02613 seconds
Time Before: 0.02857 seconds
Time After: 0.02982 seconds
Time Before: 0.02511 seconds
Time After: 0.03003 seconds
Time Taken: 0.00493 seconds
Time Before: 0.04127 seconds
Time After: 0.04142 seconds
Time Before: 0.04952 seconds
Time After: 0.05077 seconds
Time Before: 0.05700 seconds
Time After: 0.05721 seconds
Time Before: 0.05976 seconds
Time After: 0.06120 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102514' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.07690 seconds
Time After: 0.07720 seconds
