Time Before: 0.01440 seconds
Time After: 0.01801 seconds
Time Taken: 0.00361 seconds
Time Before: 0.01813 seconds
Time After: 0.01850 seconds
Time Before: 0.01876 seconds
Time After: 0.01897 seconds
Time Before: 0.01978 seconds
Time After: 0.02169 seconds
Time Taken: 0.00191 seconds
Time Before: 0.01905 seconds
Time After: 0.02614 seconds
Time Taken: 0.00709 seconds
Time Before: 0.03341 seconds
Time After: 0.03375 seconds
Time Before: 0.03644 seconds
Time After: 0.03762 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03252 seconds
Time After: 0.03782 seconds
Time Taken: 0.00530 seconds
Time Before: 0.05837 seconds
Time After: 0.05854 seconds
Time Before: 0.07023 seconds
Time After: 0.07150 seconds
End call of global.php: 0.073832035064697
Time Before: 0.07868 seconds
Time After: 0.07889 seconds
Time Before: 0.08159 seconds
Time After: 0.08308 seconds
SET lastactivity = 1788961237, location = '/forums/private.php?do=newpm&explain=1&u=102532', badlocation = 1
Time Before: 0.09911 seconds
Time After: 0.09940 seconds
Page generated in 0.098093032836914 seconds with 9 queries, spending 0.0074291229248047 doing MySQL queries and 0.090663909912109 doing PHP things.
