Time Before: 0.03542 seconds
Time After: 0.04817 seconds
Time Taken: 0.01276 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.04827 seconds
Time After: 0.04867 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.04893 seconds
Time After: 0.04913 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.04987 seconds
Time After: 0.05293 seconds
Time Taken: 0.00306 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.04919 seconds
Time After: 0.05671 seconds
Time Taken: 0.00752 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.06910 seconds
Time After: 0.06950 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.07195 seconds
Time After: 0.07314 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.06842 seconds
Time After: 0.07338 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.15116 seconds
Time After: 0.15134 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.56635 seconds
Time After: 0.56815 seconds
Time Taken: 0.00180 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
Time Before: 0.60782 seconds
Time After: 0.60798 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.61731 seconds
Time After: 0.61895 seconds
Time Taken: 0.00164 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102588', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.65292 seconds
Time After: 0.65321 seconds
Memory Before: 5,998.508 KB
Memory After: 5,998.727 KB
