Time Before: 0.00145 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00247 seconds
Time Before: 0.00274 seconds
Time After: 0.00289 seconds
Time Before: 0.00366 seconds
Time After: 0.00619 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00297 seconds
Time After: 0.00959 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01232 seconds
Time After: 0.01272 seconds
Time Before: 0.01506 seconds
Time After: 0.01622 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01159 seconds
Time After: 0.01641 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02185 seconds
Time After: 0.02197 seconds
Time Before: 0.02439 seconds
Time After: 0.02561 seconds
End call of global.php: 0.027294874191284
Time Before: 0.02853 seconds
Time After: 0.02869 seconds
Time Before: 0.03064 seconds
Time After: 0.03207 seconds
SET lastactivity = 1776608053, location = '/forums/private.php?do=newpm&explain=1&u=102639'
Time Before: 0.04436 seconds
Time After: 0.04465 seconds
Page generated in 0.043459892272949 seconds with 9 queries, spending 0.0079388618469238 doing MySQL queries and 0.035521030426025 doing PHP things.
