Time Before: 0.02610 seconds
Time After: 0.03339 seconds
Time Taken: 0.00729 seconds
Time Before: 0.03348 seconds
Time After: 0.03420 seconds
Time Taken: 0.00072 seconds
Time Before: 0.03475 seconds
Time After: 0.03489 seconds
Time Before: 0.03575 seconds
Time After: 0.03846 seconds
Time Taken: 0.00270 seconds
Time Before: 0.03498 seconds
Time After: 0.04403 seconds
Time Taken: 0.00906 seconds
Time Before: 0.04941 seconds
Time After: 0.04970 seconds
Time Before: 0.05216 seconds
Time After: 0.05338 seconds
Time Before: 0.04886 seconds
Time After: 0.05361 seconds
Time Taken: 0.00475 seconds
Time Before: 0.10665 seconds
Time After: 0.10678 seconds
Time Before: 0.12369 seconds
Time After: 0.12491 seconds
Time Before: 0.13638 seconds
Time After: 0.13651 seconds
Time Before: 0.13951 seconds
Time After: 0.14095 seconds
UPDATE session SET lastactivity = 1788986539, location = '/forums/private.php?do=newpm&explain=1&u=102642' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15970 seconds
Time After: 0.15994 seconds
