Time Before: 0.02568 seconds
Time After: 0.03078 seconds
Time Taken: 0.00510 seconds
Time Before: 0.03089 seconds
Time After: 0.03140 seconds
Time Before: 0.03163 seconds
Time After: 0.03176 seconds
Time Before: 0.03258 seconds
Time After: 0.03495 seconds
Time Taken: 0.00238 seconds
Time Before: 0.03184 seconds
Time After: 0.03905 seconds
Time Taken: 0.00721 seconds
Time Before: 0.04589 seconds
Time After: 0.04629 seconds
Time Before: 0.04782 seconds
Time After: 0.04901 seconds
Time Before: 0.04506 seconds
Time After: 0.04925 seconds
Time Taken: 0.00419 seconds
Time Before: 0.10773 seconds
Time After: 0.10788 seconds
Time Before: 0.19531 seconds
Time After: 0.19656 seconds
Time Before: 0.21008 seconds
Time After: 0.21026 seconds
Time Before: 0.21309 seconds
Time After: 0.21471 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1784802554, location = '/forums/private.php?do=newpm&explain=1&u=102683', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.23385 seconds
Time After: 0.23422 seconds
