Time Before: 0.02318 seconds
Time After: 0.02818 seconds
Time Taken: 0.00500 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02828 seconds
Time After: 0.02916 seconds
Time Taken: 0.00088 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02949 seconds
Time After: 0.02961 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03041 seconds
Time After: 0.03315 seconds
Time Taken: 0.00274 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02966 seconds
Time After: 0.03725 seconds
Time Taken: 0.00759 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04502 seconds
Time After: 0.04541 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04688 seconds
Time After: 0.04814 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04429 seconds
Time After: 0.04840 seconds
Time Taken: 0.00411 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.07860 seconds
Time After: 0.07890 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.25704 seconds
Time After: 0.25827 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
End call of global.php: 0.26030898094177
Time Before: 0.27804 seconds
Time After: 0.27819 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.28280 seconds
Time After: 0.28426 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=102690', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.30860 seconds
Time After: 0.30889 seconds
Memory Before: 5,997.781 KB
Memory After: 5,998.008 KB
Page generated in 0.30761504173279 seconds with 9 queries, spending 0.0088064670562744 doing MySQL queries and 0.29880857467651 doing PHP things.
