Time Before: 0.00156 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00285 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00317 seconds
Time After: 0.00342 seconds
Time Before: 0.00421 seconds
Time After: 0.00657 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00349 seconds
Time After: 0.01003 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01188 seconds
Time After: 0.01226 seconds
Time Before: 0.01487 seconds
Time After: 0.01617 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01129 seconds
Time After: 0.01635 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02157 seconds
Time After: 0.02173 seconds
Time Before: 0.02369 seconds
Time After: 0.02498 seconds
Time Before: 0.02780 seconds
Time After: 0.02796 seconds
Time Before: 0.02991 seconds
Time After: 0.03137 seconds
UPDATE session SET lastactivity = 1785364378, location = '/forums/private.php?do=newpm&explain=1&u=102701', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04709 seconds
Time After: 0.04737 seconds
