Time Before: 0.00139 seconds
Time After: 0.00208 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00215 seconds
Time After: 0.00283 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00319 seconds
Time After: 0.00346 seconds
Time Before: 0.00438 seconds
Time After: 0.00705 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00351 seconds
Time After: 0.01051 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01273 seconds
Time After: 0.01317 seconds
Time Before: 0.01476 seconds
Time After: 0.01741 seconds
Time Before: 0.01192 seconds
Time After: 0.01759 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02595 seconds
Time After: 0.02617 seconds
Time Before: 0.02819 seconds
Time After: 0.02946 seconds
Time Before: 0.03273 seconds
Time After: 0.03317 seconds
Time Before: 0.03575 seconds
Time After: 0.03721 seconds
UPDATE session SET lastactivity = 1788895968, location = '/forums/private.php?do=newpm&explain=1&u=102703', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05064 seconds
Time After: 0.05089 seconds
