Time Before: 0.00204 seconds
Time After: 0.00277 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00292 seconds
Time After: 0.00337 seconds
Time Before: 0.00359 seconds
Time After: 0.00369 seconds
Time Before: 0.00445 seconds
Time After: 0.00664 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00374 seconds
Time After: 0.01072 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01254 seconds
Time After: 0.01294 seconds
Time Before: 0.01417 seconds
Time After: 0.01536 seconds
Time Before: 0.01193 seconds
Time After: 0.01554 seconds
Time Taken: 0.00361 seconds
Time Before: 0.02137 seconds
Time After: 0.02154 seconds
Time Before: 0.02370 seconds
Time After: 0.02491 seconds
Time Before: 0.02785 seconds
Time After: 0.02798 seconds
Time Before: 0.03000 seconds
Time After: 0.03150 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1783117456, location = '/forums/private.php?do=newpm&explain=1&u=102714' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04401 seconds
Time After: 0.04441 seconds
