Time Before: 0.00148 seconds
Time After: 0.00207 seconds
Time Taken: 0.00059 seconds
Memory Before: 532.289 KB
Memory After: 557.406 KB
Time Before: 0.00213 seconds
Time After: 0.00270 seconds
Time Taken: 0.00057 seconds
Memory Before: 557.344 KB
Memory After: 558.352 KB
Time Before: 0.00296 seconds
Time After: 0.00310 seconds
Memory Before: 558.906 KB
Memory After: 559.430 KB
Time Before: 0.00399 seconds
Time After: 0.00803 seconds
Time Taken: 0.00405 seconds
Memory Before: 562.031 KB
Memory After: 562.953 KB
Time Before: 0.00314 seconds
Time After: 0.01141 seconds
Time Taken: 0.00827 seconds
Memory Before: 558.680 KB
Memory After: 1,639.734 KB
Memory Used: 1,081.055 KB
Time Before: 0.01336 seconds
Time After: 0.01380 seconds
Memory Before: 2,134.656 KB
Memory After: 2,135.273 KB
Time Before: 0.01657 seconds
Time After: 0.01885 seconds
Time Taken: 0.00228 seconds
Memory Before: 2,146.836 KB
Memory After: 2,146.695 KB
Time Before: 0.01268 seconds
Time After: 0.01904 seconds
Time Taken: 0.00636 seconds
Memory Before: 2,126.836 KB
Memory After: 2,260.047 KB
Memory Used: 133.211 KB
Time Before: 0.02404 seconds
Time After: 0.02420 seconds
Memory Before: 2,813.594 KB
Memory After: 2,814.109 KB
Time Before: 0.02627 seconds
Time After: 0.02757 seconds
Memory Before: 2,901.883 KB
Memory After: 2,902.477 KB
End call of global.php: 0.029168844223022
Time Before: 0.03131 seconds
Time After: 0.03144 seconds
Memory Before: 3,538.656 KB
Memory After: 3,539.086 KB
Time Before: 0.03339 seconds
Time After: 0.03482 seconds
Memory Before: 3,820.188 KB
Memory After: 3,821.875 KB
SET lastactivity = 1789042247, location = '/forums/private.php?do=newpm&explain=1&u=102720', badlocation = 1
Time Before: 0.04731 seconds
Time After: 0.04764 seconds
Memory Before: 4,298.773 KB
Memory After: 4,298.984 KB
Page generated in 0.046446800231934 seconds with 9 queries, spending 0.010817050933838 doing MySQL queries and 0.035629749298096 doing PHP things.
