Time Before: 0.00144 seconds
Time After: 0.00197 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00203 seconds
Time After: 0.00261 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00282 seconds
Time After: 0.00293 seconds
Time Before: 0.00379 seconds
Time After: 0.00654 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00298 seconds
Time After: 0.00995 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01190 seconds
Time After: 0.01231 seconds
Time Before: 0.01471 seconds
Time After: 0.01594 seconds
Time Before: 0.01135 seconds
Time After: 0.01620 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02158 seconds
Time After: 0.02180 seconds
Time Before: 0.02426 seconds
Time After: 0.02557 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02969 seconds
Time After: 0.02987 seconds
Time Before: 0.03267 seconds
Time After: 0.03429 seconds
Time Taken: 0.00162 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102732' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04800 seconds
Time After: 0.04842 seconds
