Time Before: 0.02378 seconds
Time After: 0.03267 seconds
Time Taken: 0.00889 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.03278 seconds
Time After: 0.03319 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.03346 seconds
Time After: 0.03362 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.03438 seconds
Time After: 0.03760 seconds
Time Taken: 0.00322 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.03369 seconds
Time After: 0.04176 seconds
Time Taken: 0.00807 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.05276 seconds
Time After: 0.05317 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.05576 seconds
Time After: 0.05695 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.05191 seconds
Time After: 0.05719 seconds
Time Taken: 0.00528 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.09341 seconds
Time After: 0.09357 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.11385 seconds
Time After: 0.11542 seconds
Time Taken: 0.00158 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
Time Before: 0.12558 seconds
Time After: 0.12573 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.12857 seconds
Time After: 0.13001 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
UPDATE session SET lastactivity = 1788897283, location = '/forums/private.php?do=newpm&explain=1&u=102751' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.15028 seconds
Time After: 0.15055 seconds
Memory Before: 4,295.383 KB
Memory After: 4,295.609 KB
