Time Before: 0.04030 seconds
Time After: 0.04790 seconds
Time Taken: 0.00760 seconds
Time Before: 0.04800 seconds
Time After: 0.04843 seconds
Time Before: 0.04873 seconds
Time After: 0.04891 seconds
Time Before: 0.04962 seconds
Time After: 0.05155 seconds
Time Taken: 0.00193 seconds
Time Before: 0.04896 seconds
Time After: 0.05547 seconds
Time Taken: 0.00651 seconds
Time Before: 0.06754 seconds
Time After: 0.06793 seconds
Time Before: 0.07023 seconds
Time After: 0.07147 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06665 seconds
Time After: 0.07169 seconds
Time Taken: 0.00504 seconds
Memory After: 2,261.820 KB
Time Before: 0.12878 seconds
Time After: 0.12895 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.42710 seconds
Time After: 0.42841 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.44457 seconds
Time After: 0.44475 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.44809 seconds
Time After: 0.44956 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788958563, location = '/forums/private.php?do=newpm&explain=1&u=102803' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.47136 seconds
Time After: 0.47284 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
