Time Before: 0.03267 seconds
Time After: 0.03795 seconds
Time Taken: 0.00528 seconds
Time Before: 0.03805 seconds
Time After: 0.03842 seconds
Time Before: 0.03863 seconds
Time After: 0.03877 seconds
Time Before: 0.03951 seconds
Time After: 0.04202 seconds
Time Taken: 0.00251 seconds
Time Before: 0.03882 seconds
Time After: 0.04613 seconds
Time Taken: 0.00730 seconds
Time Before: 0.05996 seconds
Time After: 0.06036 seconds
Time Before: 0.06176 seconds
Time After: 0.06297 seconds
Time Before: 0.05931 seconds
Time After: 0.06318 seconds
Time Taken: 0.00387 seconds
Time Before: 0.11794 seconds
Time After: 0.11808 seconds
Time Before: 0.15978 seconds
Time After: 0.16109 seconds
Time Taken: 0.00131 seconds
Time Before: 0.17939 seconds
Time After: 0.17961 seconds
Time Before: 0.18247 seconds
Time After: 0.18398 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=10282' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.20593 seconds
Time After: 0.20620 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
