Time Before: 0.00271 seconds
Time After: 0.00325 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00333 seconds
Time After: 0.00382 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00404 seconds
Time After: 0.00414 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00485 seconds
Time After: 0.00741 seconds
Time Taken: 0.00255 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00419 seconds
Time After: 0.01081 seconds
Time Taken: 0.00662 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01287 seconds
Time After: 0.01333 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01576 seconds
Time After: 0.01710 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01222 seconds
Time After: 0.01729 seconds
Time Taken: 0.00507 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02358 seconds
Time After: 0.02381 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03109 seconds
Time After: 0.03241 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.034043073654175
Time Before: 0.04058 seconds
Time After: 0.04071 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04309 seconds
Time After: 0.04461 seconds
Time Taken: 0.00152 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=102823'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.05992 seconds
Time After: 0.06024 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.058829069137573 seconds with 9 queries, spending 0.0084540843963623 doing MySQL queries and 0.050374984741211 doing PHP things.
