Time Before: 0.00139 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00247 seconds
Time Before: 0.00275 seconds
Time After: 0.00288 seconds
Time Before: 0.00373 seconds
Time After: 0.00648 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00293 seconds
Time After: 0.01204 seconds
Time Taken: 0.00911 seconds
Time Before: 0.01473 seconds
Time After: 0.01515 seconds
Time Before: 0.01658 seconds
Time After: 0.01787 seconds
Time Before: 0.01380 seconds
Time After: 0.01804 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02413 seconds
Time After: 0.02433 seconds
Time Before: 0.02687 seconds
Time After: 0.02809 seconds
Time Before: 0.03196 seconds
Time After: 0.03212 seconds
Time Before: 0.03427 seconds
Time After: 0.03575 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102850', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04993 seconds
Time After: 0.05027 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
