Time Before: 0.02223 seconds
Time After: 0.02655 seconds
Time Taken: 0.00432 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02665 seconds
Time After: 0.02732 seconds
Time Taken: 0.00067 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02757 seconds
Time After: 0.02772 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02839 seconds
Time After: 0.03164 seconds
Time Taken: 0.00325 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02777 seconds
Time After: 0.03507 seconds
Time Taken: 0.00729 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04085 seconds
Time After: 0.04124 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04349 seconds
Time After: 0.04642 seconds
Time Taken: 0.00293 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04018 seconds
Time After: 0.04661 seconds
Time Taken: 0.00644 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08264 seconds
Time After: 0.08283 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.13283 seconds
Time After: 0.13416 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.16531 seconds
Time After: 0.16597 seconds
Time Taken: 0.00066 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.17096 seconds
Time After: 0.17290 seconds
Time Taken: 0.00195 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1769150303, location = '/forums/private.php?do=newpm&explain=1&u=102851', badlocation = 1 WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.20135 seconds
Time After: 0.20166 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
