Time Before: 0.00897 seconds
Time After: 0.01273 seconds
Time Taken: 0.00376 seconds
Time Before: 0.01282 seconds
Time After: 0.01322 seconds
Time Before: 0.01346 seconds
Time After: 0.01359 seconds
Time Before: 0.01435 seconds
Time After: 0.01645 seconds
Time Taken: 0.00210 seconds
Time Before: 0.01366 seconds
Time After: 0.02055 seconds
Time Taken: 0.00689 seconds
Time Before: 0.02539 seconds
Time After: 0.02575 seconds
Time Before: 0.02834 seconds
Time After: 0.02959 seconds
Time Before: 0.02474 seconds
Time After: 0.02977 seconds
Time Taken: 0.00503 seconds
Time Before: 0.04571 seconds
Time After: 0.04585 seconds
Time Before: 0.05447 seconds
Time After: 0.05574 seconds
End call of global.php: 0.058034181594849
Time Before: 0.06214 seconds
Time After: 0.06230 seconds
Time Before: 0.06516 seconds
Time After: 0.06705 seconds
Time Taken: 0.00190 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102870', badlocation = 1
Time Before: 0.08532 seconds
Time After: 0.08559 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.084134101867676 seconds with 9 queries, spending 0.0079998970031738 doing MySQL queries and 0.076134204864502 doing PHP things.
