Time Before: 0.01260 seconds
Time After: 0.01600 seconds
Time Taken: 0.00340 seconds
Time Before: 0.01611 seconds
Time After: 0.01670 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01696 seconds
Time After: 0.01710 seconds
Time Before: 0.01785 seconds
Time After: 0.02044 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01716 seconds
Time After: 0.02476 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03413 seconds
Time After: 0.03457 seconds
Time Before: 0.03705 seconds
Time After: 0.03827 seconds
Time Before: 0.03350 seconds
Time After: 0.03847 seconds
Time Taken: 0.00496 seconds
Time Before: 0.07219 seconds
Time After: 0.07234 seconds
Time Before: 0.08594 seconds
Time After: 0.08716 seconds
End call of global.php: 0.089035987854004
Time Before: 0.09445 seconds
Time After: 0.09465 seconds
Time Before: 0.09697 seconds
Time After: 0.09842 seconds
SET lastactivity = 1785340787, location = '/forums/private.php?do=newpm&explain=1&u=102872'
Time Before: 0.11708 seconds
Time After: 0.11737 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.11599588394165 seconds with 9 queries, spending 0.0082738399505615 doing MySQL queries and 0.10772204399109 doing PHP things.
