Time Before: 0.01159 seconds
Time After: 0.01472 seconds
Time Taken: 0.00312 seconds
Time Before: 0.01483 seconds
Time After: 0.01544 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01565 seconds
Time After: 0.01579 seconds
Time Before: 0.01657 seconds
Time After: 0.01874 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01586 seconds
Time After: 0.02365 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02944 seconds
Time After: 0.02984 seconds
Time Before: 0.03252 seconds
Time After: 0.03372 seconds
Time Before: 0.02862 seconds
Time After: 0.03392 seconds
Time Taken: 0.00530 seconds
Time Before: 0.04913 seconds
Time After: 0.04929 seconds
Time Before: 0.05852 seconds
Time After: 0.05979 seconds
End call of global.php: 0.062080144882202
Time Before: 0.06642 seconds
Time After: 0.06663 seconds
Time Before: 0.06935 seconds
Time After: 0.07078 seconds
SET lastactivity = 1784883038, location = '/forums/private.php?do=newpm&explain=1&u=102879', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.08961 seconds
Time After: 0.08993 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.088188171386719 seconds with 9 queries, spending 0.0078837871551514 doing MySQL queries and 0.080304384231567 doing PHP things.
