Time Before: 0.00204 seconds
Time After: 0.00307 seconds
Time Taken: 0.00103 seconds
Time Before: 0.00314 seconds
Time After: 0.00446 seconds
Time Taken: 0.00132 seconds
Time Before: 0.00467 seconds
Time After: 0.00480 seconds
Time Before: 0.00562 seconds
Time After: 0.00779 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00484 seconds
Time After: 0.01247 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01490 seconds
Time After: 0.01531 seconds
Time Before: 0.01714 seconds
Time After: 0.01841 seconds
Time Before: 0.01416 seconds
Time After: 0.01868 seconds
Time Taken: 0.00452 seconds
Time Before: 0.02907 seconds
Time After: 0.02922 seconds
Time Before: 0.03308 seconds
Time After: 0.03435 seconds
End call of global.php: 0.03704309463501
Time Before: 0.03869 seconds
Time After: 0.03886 seconds
Time Before: 0.04193 seconds
Time After: 0.04342 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102896'
Time Before: 0.06018 seconds
Time After: 0.06048 seconds
Page generated in 0.059242010116577 seconds with 9 queries, spending 0.0086541175842285 doing MySQL queries and 0.050587892532349 doing PHP things.
