Time Before: 0.00211 seconds
Time After: 0.00272 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00282 seconds
Time After: 0.00326 seconds
Time Before: 0.00350 seconds
Time After: 0.00367 seconds
Time Before: 0.00456 seconds
Time After: 0.00730 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00375 seconds
Time After: 0.01114 seconds
Time Taken: 0.00739 seconds
Time Before: 0.01320 seconds
Time After: 0.01362 seconds
Time Before: 0.01605 seconds
Time After: 0.01741 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01262 seconds
Time After: 0.01765 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02282 seconds
Time After: 0.02295 seconds
Time Before: 0.02500 seconds
Time After: 0.02629 seconds
End call of global.php: 0.028445959091187
Time Before: 0.02977 seconds
Time After: 0.03017 seconds
Time Before: 0.03220 seconds
Time After: 0.03365 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102905'
Time Before: 0.04786 seconds
Time After: 0.04812 seconds
Page generated in 0.046926975250244 seconds with 9 queries, spending 0.0086433887481689 doing MySQL queries and 0.038283586502075 doing PHP things.
