Time Before: 0.00350 seconds
Time After: 0.00462 seconds
Time Taken: 0.00112 seconds
Time Before: 0.00468 seconds
Time After: 0.00510 seconds
Time Before: 0.00532 seconds
Time After: 0.00548 seconds
Time Before: 0.00639 seconds
Time After: 0.00891 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00558 seconds
Time After: 0.01426 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01784 seconds
Time After: 0.01823 seconds
Time Before: 0.02101 seconds
Time After: 0.02228 seconds
Time Before: 0.01703 seconds
Time After: 0.02251 seconds
Time Taken: 0.00548 seconds
Time Before: 0.03125 seconds
Time After: 0.03146 seconds
Time Before: 0.03563 seconds
Time After: 0.03690 seconds
Time Before: 0.04016 seconds
Time After: 0.04029 seconds
Time Before: 0.04235 seconds
Time After: 0.04392 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1783020913, location = '/forums/private.php?do=newpm&explain=1&u=102907' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05682 seconds
Time After: 0.05711 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
