Time Before: 0.00210 seconds
Time After: 0.00290 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00300 seconds
Time After: 0.00348 seconds
Time Before: 0.00376 seconds
Time After: 0.00393 seconds
Time Before: 0.00481 seconds
Time After: 0.00717 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00400 seconds
Time After: 0.01181 seconds
Time Taken: 0.00780 seconds
Time Before: 0.01361 seconds
Time After: 0.01397 seconds
Time Before: 0.01658 seconds
Time After: 0.01775 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01305 seconds
Time After: 0.01800 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.703 KB
Time Before: 0.02526 seconds
Time After: 0.02544 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02793 seconds
Time After: 0.02980 seconds
Time Taken: 0.00187 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03294 seconds
Time After: 0.03309 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03535 seconds
Time After: 0.03678 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102911', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05075 seconds
Time After: 0.05113 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
