Time Before: 0.00442 seconds
Time After: 0.00654 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00661 seconds
Time After: 0.00710 seconds
Time Before: 0.00738 seconds
Time After: 0.00753 seconds
Time Before: 0.00821 seconds
Time After: 0.01104 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00758 seconds
Time After: 0.01446 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01804 seconds
Time After: 0.01849 seconds
Time Before: 0.02093 seconds
Time After: 0.02215 seconds
Time Before: 0.01740 seconds
Time After: 0.02235 seconds
Time Taken: 0.00494 seconds
Time Before: 0.03153 seconds
Time After: 0.03170 seconds
Time Before: 0.03781 seconds
Time After: 0.03908 seconds
End call of global.php: 0.040995121002197
Time Before: 0.04275 seconds
Time After: 0.04294 seconds
Time Before: 0.04593 seconds
Time After: 0.04856 seconds
Time Taken: 0.00263 seconds
SET lastactivity = 1772738966, location = '/forums/private.php?do=newpm&explain=1&u=102916'
Time Before: 0.06436 seconds
Time After: 0.06467 seconds
Page generated in 0.063432931900024 seconds with 9 queries, spending 0.0097169876098633 doing MySQL queries and 0.053715944290161 doing PHP things.
