Time Before: 0.01913 seconds
Time After: 0.02578 seconds
Time Taken: 0.00665 seconds
Time Before: 0.02588 seconds
Time After: 0.02637 seconds
Time Before: 0.02664 seconds
Time After: 0.02680 seconds
Time Before: 0.02761 seconds
Time After: 0.03036 seconds
Time Taken: 0.00275 seconds
Time Before: 0.02688 seconds
Time After: 0.03517 seconds
Time Taken: 0.00829 seconds
Time Before: 0.04125 seconds
Time After: 0.04169 seconds
Time Before: 0.04343 seconds
Time After: 0.04467 seconds
Time Before: 0.04054 seconds
Time After: 0.04487 seconds
Time Taken: 0.00433 seconds
Time Before: 0.07324 seconds
Time After: 0.07340 seconds
Time Before: 0.08811 seconds
Time After: 0.08938 seconds
End call of global.php: 0.092077970504761
Time Before: 0.10006 seconds
Time After: 0.10022 seconds
Time Before: 0.10255 seconds
Time After: 0.10399 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102918'
Time Before: 0.12111 seconds
Time After: 0.12139 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.12015604972839 seconds with 9 queries, spending 0.0083928108215332 doing MySQL queries and 0.11176323890686 doing PHP things.
