Time Before: 0.01854 seconds
Time After: 0.02528 seconds
Time Taken: 0.00674 seconds
Time Before: 0.02541 seconds
Time After: 0.02585 seconds
Time Before: 0.02684 seconds
Time After: 0.02699 seconds
Time Before: 0.02775 seconds
Time After: 0.02989 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02705 seconds
Time After: 0.03416 seconds
Time Taken: 0.00711 seconds
Time Before: 0.03853 seconds
Time After: 0.03897 seconds
Time Before: 0.04153 seconds
Time After: 0.04286 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03784 seconds
Time After: 0.04308 seconds
Time Taken: 0.00524 seconds
Time Before: 0.07102 seconds
Time After: 0.07117 seconds
Time Before: 0.08320 seconds
Time After: 0.08451 seconds
Time Taken: 0.00131 seconds
Time Before: 0.09671 seconds
Time After: 0.09693 seconds
Time Before: 0.10009 seconds
Time After: 0.10154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102921', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.12119 seconds
Time After: 0.12145 seconds
