Time Before: 0.01033 seconds
Time After: 0.01435 seconds
Time Taken: 0.00402 seconds
Time Before: 0.01444 seconds
Time After: 0.01490 seconds
Time Before: 0.01534 seconds
Time After: 0.01552 seconds
Time Before: 0.01653 seconds
Time After: 0.01921 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01557 seconds
Time After: 0.02357 seconds
Time Taken: 0.00800 seconds
Time Before: 0.02904 seconds
Time After: 0.02928 seconds
Time Before: 0.03205 seconds
Time After: 0.03414 seconds
Time Taken: 0.00209 seconds
Time Before: 0.02837 seconds
Time After: 0.03434 seconds
Time Taken: 0.00596 seconds
Time Before: 0.05155 seconds
Time After: 0.05171 seconds
Time Before: 0.06025 seconds
Time After: 0.06152 seconds
Time Before: 0.06799 seconds
Time After: 0.06813 seconds
Time Before: 0.07045 seconds
Time After: 0.07190 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102959', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.08828 seconds
Time After: 0.08862 seconds
