Time Before: 0.02864 seconds
Time After: 0.03487 seconds
Time Taken: 0.00623 seconds
Time Before: 0.03497 seconds
Time After: 0.03542 seconds
Time Before: 0.03565 seconds
Time After: 0.03579 seconds
Time Before: 0.03660 seconds
Time After: 0.03952 seconds
Time Taken: 0.00292 seconds
Time Before: 0.03585 seconds
Time After: 0.04513 seconds
Time Taken: 0.00929 seconds
Time Before: 0.05342 seconds
Time After: 0.05386 seconds
Time Before: 0.05680 seconds
Time After: 0.05803 seconds
Time Before: 0.05281 seconds
Time After: 0.05828 seconds
Time Taken: 0.00547 seconds
Time Before: 0.10658 seconds
Time After: 0.10673 seconds
Time Before: 0.11955 seconds
Time After: 0.12079 seconds
Time Before: 0.13421 seconds
Time After: 0.13436 seconds
Time Before: 0.13724 seconds
Time After: 0.13879 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102961', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.16022 seconds
Time After: 0.16050 seconds
