Time Before: 0.00158 seconds
Time After: 0.00214 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00221 seconds
Time After: 0.00291 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00321 seconds
Time After: 0.00347 seconds
Time Before: 0.00433 seconds
Time After: 0.00763 seconds
Time Taken: 0.00330 seconds
Time Before: 0.00355 seconds
Time After: 0.01225 seconds
Time Taken: 0.00870 seconds
Time Before: 0.01421 seconds
Time After: 0.01468 seconds
Time Before: 0.01708 seconds
Time After: 0.01836 seconds
Time Before: 0.01350 seconds
Time After: 0.01856 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02347 seconds
Time After: 0.02366 seconds
Time Before: 0.02559 seconds
Time After: 0.02684 seconds
Time Before: 0.02965 seconds
Time After: 0.02993 seconds
Time Before: 0.03190 seconds
Time After: 0.03343 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102978', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04572 seconds
Time After: 0.04608 seconds
