Time Before: 0.01033 seconds
Time After: 0.01503 seconds
Time Taken: 0.00470 seconds
Time Before: 0.01510 seconds
Time After: 0.01551 seconds
Time Before: 0.01569 seconds
Time After: 0.01580 seconds
Time Before: 0.01646 seconds
Time After: 0.01950 seconds
Time Taken: 0.00304 seconds
Time Before: 0.01585 seconds
Time After: 0.02337 seconds
Time Taken: 0.00751 seconds
Time Before: 0.02769 seconds
Time After: 0.02809 seconds
Time Before: 0.03054 seconds
Time After: 0.03177 seconds
Time Before: 0.02700 seconds
Time After: 0.03201 seconds
Time Taken: 0.00500 seconds
Time Before: 0.04778 seconds
Time After: 0.04793 seconds
Time Before: 0.05562 seconds
Time After: 0.05695 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.059329032897949
Time Before: 0.06457 seconds
Time After: 0.06479 seconds
Time Before: 0.06699 seconds
Time After: 0.06844 seconds
SET lastactivity = 1776553228, location = '/forums/private.php?do=newpm&explain=1&u=102983', badlocation = 1
Time Before: 0.08615 seconds
Time After: 0.08643 seconds
Page generated in 0.085208892822266 seconds with 9 queries, spending 0.0086266994476318 doing MySQL queries and 0.076582193374634 doing PHP things.
